back washer pisser.....
MJTrippy
02-27-2005, 11:56 PM
My 95 chevy blazer the back washer fluid doesn’t come out, the motor doesn’t work for the back one, I replaced it with a brand new motor still doesn’t work, the wiper works, just the washer motor doesn’t turn on when I hit the switch…….. (the frount one works).......what should i do or test, oh yea all fuse's are all good,.......
BlazerLT
02-28-2005, 02:03 AM
You do know there are two separate pumps right?
ricksza
02-28-2005, 04:59 AM
Test for power and ground at the rear washer pump when the button is pressed. The rear washer pump is the upper one in the bottle.
rlith
02-28-2005, 06:27 AM
Since you've replaced the motor (top one not the bottom one on the tank right?) I would be looking at the switch....
Allbert
02-28-2005, 09:35 AM
I thought mine didn't work at first, but it turns out I needed to have the switch slid up to where the wipers were already on before the washer would activate... I was expecting the wipers + washer to come on just by pushing the washer button.
MJTrippy
02-28-2005, 10:06 PM
so what do you mean allbert? i dont understand you very good.......and yes i know its the top pump.........what should i do about the switch? is there anyway to put in a new switch? and how to get it out?
rlith
02-28-2005, 10:15 PM
He means to activate the washer you have to press and hold the rear wiper switch all the way to the left to activate the pump... That said, the switch is easy to replace. Simply unplug it, push it out from the back and slip the new one in, then reattach the plug..
Allbert
03-01-2005, 08:59 AM
On my Blazer, the rear wiper switch is a sliding switch with a button in the middle, located on the dash to the right of the steering wheel. To activate the washer on mine, I thought I just had to push the button and then washer fluid would spray and the wipers would come for a few swipes, but it turns out I have to slide the switch up to the ON position first and then push the button before any washer fluid sprays out. Then I have to slide the switch back off to stop the wipers.
