Power Steering Pump, Shaft Twisted
wipeout
02-27-2005, 04:38 PM
I just finished puting a front wheel bearing on and I just pulled it out of the shop and the power steering pump failed.
This is a 2000 Montana with 106,000 k on it and it has been nothing but problems. Just wondering if anyone else has had this problem with the power steering. The impeller drive shaft twisted off at the splines, and what would cause this??
2pontiacs
03-01-2005, 11:56 AM
Was it cold outside?
Generally when it is, there might be too much load on the pump due to the viscosity of the fluid. It is best to let the vehicle warm up a bit before being too hard on the wheel.
The spline breaking is not a common occurance on these vans. They might have had a bad batch of pumps though.
I hope this helps.
I hope this helps.
wipeout
03-01-2005, 08:15 PM
It just came out of a warm shop so the oil wasn't very cold.
wipeout
03-01-2005, 08:47 PM
the new pump that has to go on, do i have to bleed it and if so how do i do that?
GTP Dad
03-02-2005, 06:37 AM
See my response to your post in nonspecific!!!
