Flasher Replacement
SRVRGRL
02-26-2005, 01:18 PM
Help! I Need To Replace The Flasher On My 1995 Intrepid, But I Can't Find It. Any Suggestions?
1thunder
02-26-2005, 09:18 PM
you have to remove the lower shield/heat duct assy
to access the flasher and it is on the left of the steering column useualy black in colour but not likely
your problem. For the most part if you signal fail it is more likely to be a wiring issue check at the positive battery post there should be a fuselink there if battery has been removed recently may have a poor conection there or burned link.Check there first
