flasher problem
froeman
02-26-2005, 11:52 AM
I have a 2002 Alero. When the turn signal returns to the centre position, the tick-tick sound keeps going (fast). Its like a bulb is burned out, but that happens when you are using the turn signals. My ticking sound is when the turn signals are NOT being used.
I replaced the hazard switch, which is also the flasher. Problem persists.
Apparently there is a recall for the 2001 models, but my dealer told me there is no recall on my model.
Any suggestions?
Any suggestions?
frankiec
02-28-2005, 07:43 PM
I have a 2001 Alero GLS. I'm having the same fast tick-tick sound that happens when I'm NOT using the turn signals. My car has 73,000 miles on it and it's out of warrentee. Does the reacll still apply??
nk567497
03-05-2005, 08:36 AM
Hello,
I have Alero 1999, and have been same problem .My question was #103,153
this is no under recall and no hazard switch . I have scematic of
hazard switch and I will try find this problem when will be no so cold.
I think problem with contact of power to hazard switch or hazard switch connector .
justwarber
03-22-2005, 07:48 AM
My 99 alero has the same problem. It is currently in the care of GM Goodwrench Service to which they state it is the Master Function Switch. The part costs $136. Hope this helps (me and you!)
goodfmly
04-02-2005, 12:01 PM
Any suggestions?
Ihave a similar problem ina 2000 alero and want to replacce the flasher but cannot find it, can you tell me where it is and what it looks like
Any suggestions?
vamc
04-06-2005, 10:44 PM
It should either be on the driver side door or under the hood. also the owners manuel will tell you
