**Recall Info** 1996 Blazer
blazee
02-25-2005, 08:47 AM
I am just posting some recall info that I found. Not all vehicles are covered by the recalls, so they may not apply to you.
Campaign Number: 03V159000 Date: 2003-Apr-28
Component: Visibility: Windshield Wiper/washer
Defect Summary: ON CERTAIN MINIVANS, PICKUP TRUCKS, AND SPORT UTILITY VEHICLES WITH CERTAIN MODEL-ENGINE COMBINATIONS, THE WINDSHIELD WIPER MOTOR MAY FAIL DUE TO CRACKED SOLDER JOINTS ON THE CONTROLLER CIRCUIT BOARD. THE WINDSHIELD WIPERS COULD WORK INTERMITTENTLY OR NOT AT ALL.
Consequence Summary: IF THIS WERE TO OCCUR DURING BAD WEATHER, DRIVER VISIBILITY WOULD BE REDUCED, WHICH COULD RESULT IN A CRASH.
Corrective Summary: DEALERS WILL REPLACE THE WIPER MOTOR CIRCUIT BOARD AND COVER. OWNER NOTIFICATION BEGAN ON JUNE 19, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT CHEVROLET AT 1-800-222-1020, GMC AT 1-800-462-8782, OR OLDSMOBILE AT 1-800-442-6537. To schedule service online click here (http://www.autosite.com/content/framed/index.cfm?id=22041;ASITE&action=myautogarage)
Campaign Number: 01I018000 Date: 2001-Dec-04
Component: Suspension: Front: Control Arm: Upper Ball Joint
Defect Summary: THIS IS NOT A SAFETY RECALL IN ACCORDANCE WITH THE SAFETY ACT. HOWEVER, IT IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN BY THE AGENCY. VEHICLE DESCRIPTION: 1996-1997 4-WHEEL DRIVE CHEVROLET BLAZER, GMC JIMMY, AND OLDSMOBILE BRAVADA SPORT UTILITY VEHICLES. SOME OWNERS HAVE HAD TO PAY FOR REPLACEMENT OF THE UPPER BALL JOINTS THAT HAVE SEPARATED. GM IS PROVIDING A SPECIAL POLICY TO THESE OWNERS TO COVER UPPER BALL JOINT REPLACEMENT IF THE CUSTOMER FOLLOWED THE RECOMMENDED MAINTENANCE SCHEDULE FOR THE CHASSIS LUBRICATION AND THE VEHICLE STILL REQUIRED THE REPLACEMENT OF THE UPPER BALL JOINTS DUE TO SEPARATION.
Consequence Summary: THIS COULD CAUSE A LOSS OF STEERING CONTROL OF THE VEHICLE.
Corrective Summary: GM HAS DECIDED TO CONDUCT A CUSTOMER SATISFACTION CAMPAIGN TO REPLACE THE UPPER BALL JOINTS ON AFFECTED VEHICLES. THIS SPECIAL POLICY IS FOR A PERIOD OF 8 YEARS OR 100,000 MILES, WHICHEVER OCCURS FIRST, FROM THE DATE THE VHEICLE WAS ORIGINALLY PLACED IN SERVICE, REGARDLESS OF OWNERSHIP. THE UPPER BALL JOINT REPLACEMENT, DUE TO SEPARATION, WILL BE MADE AT NO CHARGE TO THE CUSTOMER DURING THIS PERIOD. OWNERS CAN CONTACT CHEVROLET AT 1-800-222-1020, GMC AT 1-800-862-4389, OR OLDSMOBILE AT 1-800-442-6537, CONCERNING THIS PROGRAM. To schedule service online click here (http://www.autosite.com/content/framed/index.cfm?id=22041;ASITE&action=myautogarage)
Campaign Number: 01V200000 Date: 2001-Jun-28
Defect Summary: ON CERTAIN SPORT UTILITY VEHICLES ORIGINALLY SOLD OR CURRENTLY REGISTERED IN THE STATES OF CONNECTICUT, DELAWARE, ILLINOIS, INDIANA, IOWA, MAINE, MARYLAND, MASSACHUSETTS, MICHIGAN, MINNESOTA, MISSOURI, NEW HAMPSHIRE, NEW JERSEY, NEW YORK, OHIO, PENNSYLVANIA, RHODE ISLAND, VERMONT, WEST VIRGINIA, AND WISCONSIN, AND IN THE DISTRICT OF COLUMBIA. FAILURE OF AN UPPER CONTROL ARM BALL JOINT ASSEMBLY COULD OCCUR DUE TO CORROSION.
Consequence Summary: THIS CAN RESULT IN IMPAIRED STEERING OR STEERING LOSS, OR A PARTIAL OR COMPLETE COLLAPSE OF THE FRONT SUSPENSION, INCREASING THE RISK OF A CRASH.
Corrective Summary: DEALERS WILL REPLACE BOTH UPPER BALL JOINTS. OWNER NOTIFICATION BEGAN SEPTEMBER 4, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT CHEVROLET AT 1-800-222-1020, GMC AT 1-800-462-8782, OR OLDSMOBILE AT 1-800-442-6537. To schedule service online click here (http://www.autosite.com/content/framed/index.cfm?id=22041;ASITE&action=myautogarage)
Campaign Number: 99I006000 Date: 1999-Jul-19
Component: Service Brakes, Hydraulic: Antilock
Defect Summary: THIS IS NOT A SAFETY RECALL IN ACCORDANCE WITH THE SAFETY ACT. HOWEVER, IT IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN BY THE AGENCY. VEHICLE DESCRIPTION: CERTAIN LIGHT DUTY PICKUP TRUCKS, SPORT UTILITY VEHICLES, OR MINIVANS EQUIPPED WITH 3-SENSOR ABS (ANTILOCK BRAKING SYSTEM) EBC4 UNITS.
Consequence Summary: THESE VEHICLES CAN EXPERIENCE EXTENDED STOPPING DISTANCES DURING ABS STOPS ON CERTAIN MULTIPLE SURFACES, INCREASING THE RISK OF A CRASH.
Corrective Summary: DEALERS WILL MODIFY THE COMPUTER PROGRAM WHICH OPERATES THE ABS UNIT ON SOME VEHICLES, OR REPLACE THE COMPUTER ON OTHERS TO IMPROVE THE PERFORMANCE OF THE ABS ON THESE SURFACES. To schedule service online click here (http://www.autosite.com/content/framed/index.cfm?id=22041;ASITE&action=myautogarage)
Campaign Number: 99V193000 Date: 1999-Jul-19
Defect Summary: VEHICLE DESCRIPTION: CERTAIN 4-WHEEL DRIVE PICKUP TRUCKS AND SPORT UTILITY VEHICLES EQUIPPED WITH ABS (ANTILOCK BRAKING SYSTEM) MANUFACTURED FROM SEPTEMBER 1989 THROUGH AUGUST 1996. UNDER CERTAIN DRIVING CONDITIONS THE SWITCH WHICH SIGNALS THE ABS SYSTEM WHETHER THE VEHICLE IS IN 2-WHEEL OR 4-WHEEL DRIVE CAN MALFUNCTION CAUSING INCREASED STOPPING DISTANCES DURING ABS STOPS WHILE IN THE TWO-WHEEL DRIVE MODE.
Consequence Summary: IF THIS OCCURRED AT A TIME WHEN MINIMUM STOPPING DISTANCE WAS REQUIRED, A VEHICLE CRASH COULD OCCUR WITHOUT PRIOR WARNING.
Corrective Summary: DEALERS WILL REPLACE OR REPAIR THE 4-WHEEL/2-WHEEL DRIVE SWITCH. To schedule service online click here (http://www.autosite.com/content/framed/index.cfm?id=22041;ASITE&action=myautogarage)
Campaign Number: 98V150001 Date: 1998-Jul-01
Defect Summary: VEHICLE DESCRIPTION: LIGHT DUTY PICKUP TRUCKS AND SPORT UTILITY VEHICLES, 2 AND 4-WHEEL DRIVE. SOLDER JOINTS NEAR THE WIRING HARNESS CONNECTOR CAN CRACK CAUSING THE WINDSHIELD WIPERS TO WORK INTERMITTENTLY.
Consequence Summary: THIS CONDITION CAN RESULT IN INOPERATIVE WIPERS, REDUCING A DRIVER'S VISIBILITY, AND INCREASING THE RISK OF A VEHICLE CRASH.
Corrective Summary: DEALERS WILL REPLACE THE WIPER MOTOR CIRCUIT BOARD AND COVER. To schedule service online click here (http://www.autosite.com/content/framed/index.cfm?id=22041;ASITE&action=myautogarage)
Campaign Number: 97V096001 Date: 1997-Jun-12
Component: Seat Belts
Defect Summary: VEHICLE DESCRIPTION: EXTENDED CAB PICKUP TRUCKS EQUIPPED WITH 60/40 FRONT BENCH SEATS AND EXTENDED CAB PICKUP TRUCKS AND 2-DOOR UTILITY VEHICLES EQUIPPED WITH MANUAL LOCKING RECLINER BUCKET SEATS. THE OUTBOARD SAFETY BELT WEBBING ON THE DRIVER'S AND/OR PASSENGER'S SEAT CAN SEPARATE DURING A FRONTAL IMPACT.
Consequence Summary: IF A SEPARATION OCCURRED AND THERE WERE SECONDARY CRASH EVENTS OR VEHICLE ROLLOVER, THERE WOULD BE NO BELT RESTRAINT OF THE OCCUPANT AND INCREASED INJURIES COULD OCCUR.
Corrective Summary: DEALERS WILL INSTALL A PROTECTIVE COVER OVER THE RECLINER MECHANISM. To schedule service online click here (http://www.autosite.com/content/framed/index.cfm?id=22041;ASITE&action=myautogarage)
Campaign Number: 96V234000 Date: 1996-Nov-14
Component: Fuel System, Gasoline: Storage: Tank Assembly
Defect Summary: VEHICLE DESCRIPTION: 4-DOOR, 4-WHEEL DRIVE AND ALL-WHEEL DRIVE MULTI-PURPOSE PASSENGER VEHICLES. DURING DEVELOPMENT TESTING, THE PROP SHAFT CONTACTED THE INBOARD SIDE OF THE FUEL TANK ALLOWING FUEL LEAKAGE. THIS LEAKAGE WAS IN EXCESS OF THE AMOUNT PERMITTED BY FMVSS 301, "FUEL SYSTEM INTEGRITY."
Consequence Summary: IF AN IGNITION SOURCE IS PRESENT, AND THERE IS A FUEL LEAK, A FIRE COULD OCCUR.
Corrective Summary: DEALERS WILL INSTALL ADDITIONAL SHIELDING OF THE FUEL TANK. THIS WILL BE ADDED WITHOUT REMOVING OR DISASSEMBLING THE FUEL SYSTEM. To schedule service online click here (http://www.autosite.com/content/framed/index.cfm?id=22041;ASITE&action=myautogarage)
blazee
06-22-2005, 06:12 PM
