put a turbo on a eclipse gs
eclipserunner87
02-25-2005, 09:40 AM
ho w hard would it be to put a turbo on a 1994 eclipse gs????????
1994 eclipse gs
dohc 16valve 2.0L engine
currently runnin with 140 HP (i know and for all you smartasses (not tryin to offend people) its not alot but i just got the car a year ago!!!
1995EclipseGS
02-25-2005, 10:40 AM
1994 eclipse gs
There is a thread on this topic already open...8 threads up,take a look there...
civicblumagik021
03-02-2005, 04:02 PM
swap the motor out you have to get a 4g63
helliviknow
03-02-2005, 06:02 PM
umm isnt that a 1g? doesnt he have the 4g63 nt motor? if thats the case you just gotta bolt on all the stuff from a 1g gst and your in business. You wouldn't be able to run as high of boost though on the n/t motor.
#eTurN^_d0t_
03-02-2005, 11:08 PM
Yeah I have a Eclipse 96 Gs and I wanna put a not so powerful turbo on it. Can it be done without swapin engines ?
bighauns
03-04-2005, 11:07 AM
he already has a 4g63...it is a 1g car. the turbo engine is a 4g63T.
I would say just get a new engine. It will have lower miles and all be set up for the turbo (obviously, it is a turbo engine). You can find one for pretty cheap as well, probably as cheap as the other parts.
there is more to it than just slapping on parts, you have to worry about your ECU, the compression, blah blah. It is easier if you get the turbo motor, in my opinion.
that is what I would do.
adamgtx
03-05-2005, 09:33 PM
i had the same engine you had 140hp now i have a jdm na 180hp not bad for start with no turbo
zeus999
08-10-2005, 03:02 PM
i have a 1996 eclipse with a 2.0 non turbo can i put a turbo on my motor.or can i get a gst motor
l_eclipse_l
08-10-2005, 04:42 PM
Look at the top of the board. There is a thread labeled FOR EVERYBODY INTERESTED IN TURBOING AN RS OR GS READ THIS.
-Josh-
08-10-2005, 04:51 PM
As he said, there's a sticky at the top of the threads that will give you the in depth answers you need. Welcome to AF, in the future, dont revive old threads unless you have something important to add, all your resources are here within the forum if you run a search.
