Fuel pump help
seker269
02-23-2005, 06:23 PM
I have an 89 Daytona with a fuel pump problem. The engine will crank but will not start. I do not hear the fuel pump when the key is turned on. I am also not recieving any voltage to the harness on the fuel pump. My question is what is in line that would break the voltage?
Thanks
theFREAKnasty82
02-25-2005, 02:42 AM
your ASD (AutoShutDown relay) can trip thus killing power to your fuel pump & ignition coil.
seker269
02-25-2005, 05:26 PM
Thanks. Do you know where that is located. I can pour a little fuel down the intake and it will run till it burns that fuel.
