93 sil please help no spark
hotdog43055
02-23-2005, 07:06 PM
have a 93 olds sil. i have no spark, engine will crank but it wont start, i have replaced the crank sensor, had the cam sensor and the modual tested both tested good, am running outta options, car ran fine and up at once just quit so i dont think its the coil packs anyone have any ideas? they would all be greatly appriated....
lenny_442
02-26-2005, 09:11 AM
What engine do you have? I have a 3.8L with tuned port injection. Mine keeps stalling. It doesnt skip it just stalls for no reason and it doesnt want to start back up. if I let it sit for a little while it will fire back up. I just paid 150 dollars to have it diagnosed and they had no idea what was wrong with it. Any suggestions? I was told it might be the crank sensor. Do you try the ignition module on your van? looking forward to your response.
hotdog43055
02-26-2005, 01:47 PM
What engine do you have? I have a 3.8L with tuned port injection. Mine keeps stalling. It doesnt skip it just stalls for no reason and it doesnt want to start back up. if I let it sit for a little while it will fire back up. I just paid 150 dollars to have it diagnosed and they had no idea what was wrong with it. Any suggestions? I was told it might be the crank sensor. Do you try the ignition module on your van? looking forward to your response. yes same engine and ignition module is good, does yours throw a code for a crank sensor? anyhow u can replace it for 20.00 at auto zone, but i would suggest u have an impact wrench to get the nut off the pully that was the hardest part.
lenny_442
02-27-2005, 05:38 PM
No, it doesnt throw any codes , completely stumpt on that, I have no clue whats going on with it. Thought maybe the plug wires were shorting out on each other so replaced those, now i have to change the starter tomorrow before i can drive around and see if it helped. Wish someone could give me some ideas. This is driving me nuts. Thinking maybe its my computer over heating. Maybe thats the problem with yours, only one way to find out i guess.
jalderma
09-04-2006, 07:49 PM
Did you ever find out what was wrong ? I have a '93 with a 3.8. Just replaces Crank Sensor. Still no spark. Checked the coil's and they are OK.
hotdog43055
09-04-2006, 08:15 PM
nope still sitting not running in my driveway and for the life of me i cant figure out what is wrong with the stupid thing unless it has something to do with the wireing harness
