2003 Avalon AC Filter
steve1987
02-23-2005, 09:00 AM
Where can I find directions on how to replace the passenger AC filter? It's very expensive to have the dealer do it. Thanks.
tfeld
02-23-2005, 11:59 AM
You gain access to the blower and filter from behind the glove box. First, you have to remove the glove box: pry off the finish plate inside the glove box, then disconnect the airbag harness. There are then five screws holding the box in--just remove them.
Then you just remove the filter cover, and swap out the filter. Install is the reverse.
Caveat: this is for a 2001, but I think it will probably be very similar for yours.
csaxon
02-23-2005, 04:28 PM
Should help. You need the Adobe Acrobat reader to get the Toyota pdf file.
http://members.cox.net/ekpolk3/AVALON/Avalon-AC.pdf
steve1987
02-24-2005, 04:45 PM
Thanks very much for the information. I saw this earlier, but am not sure that it's the same as the 2003. The glove box looks different.
steve1987
02-24-2005, 04:47 PM
Thanks for your help.
steve1987
02-24-2005, 04:49 PM
I may just have to bite the bullet and pay the dealer $100 to change it. The only thing I'm conerned about is the air bag.
