Water in Airtake
gfenisey
02-20-2005, 04:27 PM
My check engine light came on and I checked the air filter. It was soaking wet and the bottom of the air intake below the filter had a puddle of water in it. Did Ford put some drain holes in there or what?
I am stumped as how that much water got in there. And where's the connector for the code reader so I can turn off that engine check light?
Mike75
02-20-2005, 11:18 PM
Did you (or somebody else) ever remove the air silencer? If so, that might be the way that all of the water got in there. I removed mine, but have not had any problems with water getting up into there - and I live in Los Angeles where we have been having some SERIOUS monsoons this winter.
As for the connector, I think it's up in the very top left of your engine compartment, just in front of the passenger side dash and the heater core.
solaris=amazing
no drain holes..
you probably hit a big puddle, and water came thru the bumper/light area.. or snow..
likhootch
05-20-2005, 02:53 PM
has the radiator fluid dropped, was it just pure water? The check engine light probably came on for more than just the water, does it still come on?
Haverjake
06-20-2005, 02:35 PM
I had the exact same problem with my 96 T-Bird a few months ago.
The air inlet that is before the air cleaner box goes down and then comes back up, kind of like a plumbing trap under a sink. At the very bottom of the trap is a rubber one way valve that is supposed to drain the water out of the air inlet. When it gets stiff, the water doesn't drain and can really screw things up. I reached up and pulled the valve out and left it out, a decent amount of water came out.
The check engine light is on due to your mass air flow sensor getting wet. I had to replace mine to get the car to run right again, hopefully yours isn't too far gone.
There are also 2 TSBs on this subject as well.
