D16z6 fly wheel question?
Scott82
02-20-2005, 04:11 PM
89 CRX HF To D16z6. going to use HF Tranny, which fly wheel do i use, the HF one or the D16z6 one. Also if the D16z6 flywheel works what yr. and model clutch kit do i need? Thanks Scott
civickiller
02-20-2005, 04:44 PM
use the same clutch as the flywheel
Cjz89civic
02-20-2005, 04:46 PM
you will need to use the HF one.
Scott82
02-20-2005, 05:14 PM
So i need to take the fly wheel off my old motor and use it. are there any hf performance clutch kits offered on the net somewhere so i can at least get a little better contact with the flywheel?
jeef
02-20-2005, 06:03 PM
personally I'd use the one on the z6 its gonna be a few mm bigger, should be like 212mm compaired to the 202mm I think it is for the 89'
Scott82
02-20-2005, 06:06 PM
if i do this which clutch kit do i use?
jeef
02-20-2005, 06:21 PM
any civic from 90-98 should hae the 212 mm clutch thats what you need, and I was wrong the 88-89 is 200 mm not 202 mm and which brand is up to you, search around the info is here
Scott82
02-20-2005, 06:42 PM
i was just making sure it would all work together good.
Cjz89civic
02-20-2005, 07:46 PM
ok if you use the Hf one you will only be able to use 89 clutch set ups. If you use the Z6 one you can use any clutch setup from 90-00. This will be easier to locate a High preformance Clutch later.
Scott82
02-20-2005, 08:04 PM
Can i use the 89 SI clutch kit? and will i still use the z6 flywheel?
jeef
02-20-2005, 08:33 PM
see my post above for reference ^
you want 90' +
you want 90' +
civickiller
02-20-2005, 09:27 PM
like i said before, use the same clutch as hte flywheel you are using. if your using the z6 flywheel then use hte z6 clutch
Scott82
02-21-2005, 05:01 AM
ok now i am clear on what i need apreciate it guys
jeef
02-21-2005, 05:53 AM
BTW the HF tranny is really gonna suck... you'll still Get great gas milage, but your z6 is going to slow, I seriously suggest keeping an eye out for a Si tranny.
quiXilver
02-21-2005, 06:55 AM
:1:
Like a tiger on a leash.
:1:
Scott82
02-21-2005, 10:44 AM
oh i will eventually, plus right now the HF Tranny will be nice for gas milage cause i am doing a lot of interstate driveing, and plus i am not wanting anything crazy fast or anything right now, i just want a good reliable daily driver untill i get me another 4cyl for gas milage and build one of the two up. i have a F-150 V8 pickup that i am driving untill i get the car running so the gas is killing me
