85 t15 jimmy 2.8 timing belt? or chain?
rental blazer
02-18-2005, 12:44 AM
okay well i pressure tested my cooling systm today and found water spewing out the water pump so therefore the pump needs replacement before it blows on me on the hiway and i heard it is a good idea to change the belt/chain at the same time does my car have a timing chain or belt? and where is it? thanks in advance for any info.
rlith
02-18-2005, 05:30 AM
You have a chain, it's behind the timing cover which is behind the waterpump..
rental blazer
02-18-2005, 10:42 PM
thanks can anyone tell me when replacing the water pump at 55k miles wicth is before the 60k mile service is it reccomed that i replace the chain as well?
rlith
02-18-2005, 10:43 PM
you don't need to replace the water pump at 60k... It's good usually for at least a 100k, the timing chain will last the life of the motor usually unless your rebuilding the motor
rental blazer
02-18-2005, 11:11 PM
thanks that helps alot but i was shocked it was bad myself at only 50-55k miles on the rebuilt moter
