Gas Gauge Not Working Even After Fuel Pump Replacement
sock_s
02-16-2005, 12:06 PM
I have a 97 Blazer 4wd with 97,000 miles on it. I recently replaced the fuel pump because it has had the problems most 97 owners seem to have about this time. The fuel guage had died a long time before, but I understood the guage problem would be fixed when the whole fuel pump was replaced. Currently the guage only moves from empty to 1/4 tank. Could it now be an instrument panel problem? Please help since I have waited so long to have a working gas gauge.
BlazerLT
02-16-2005, 12:29 PM
there are two things, a sending unit and the fuel pump.
The fuel pump inserts into the sending unit in the tank and the sending unit is what measures the fuel level.
Replace your sending unit.
TypeGsR
02-16-2005, 12:33 PM
ur sending unit could be filled with gas cause of a ltl hole its happend before witch is making it say no gas if thats ur problem if ur not on E then i dont what to tell u sometimes they get filled with gas and sink to the bottom
BlazerLT
02-16-2005, 12:53 PM
Ummm.... The sensing unit is supposed to be in the gas , that is how it senses the fuel level.
ricksza
02-16-2005, 03:55 PM
You are referring to an old style brass float simular to the float in a carborator. Current vehicles use a solid plastic float, can't sink.
goodtimepete
02-16-2005, 09:24 PM
My gas gauge hasn't worked forEVER! (or at least 1-2 years) I have to reset the odometer everytime I fill up and know I need gas between 200-250 miles. How hard is it for a normal Joe to fix this or should I leave it up to a Pro/Rip Off Artist?
BlazerLT
02-16-2005, 10:00 PM
Like to have someone do it for me so I have a warraty in case something goes wrong or the install is defective.
Go to several shops and get 5 or more quotes.
All that is needed is the sending unit seeing your pump is operating properly.
ricksza
02-17-2005, 04:42 AM
Others on the site have done it, but without a lift, it's awkward. Myself, I wouldn't do it on the ground.
rlith
02-17-2005, 05:57 AM
As everyone has said, replace the sending unit. If you've already done the pump yourself (did you?) You understand how to drop the tank. I would also reccomend replacing the fuel pulsator unit (40 bux) at that miledge... I learned from a bad experience recently...
mike2004tct
02-19-2005, 05:38 PM
I did ot on the ground, I probably won't do it again.
Check out my excursion into tank removal....
http://www.automotiveforums.com/vbulletin/showthread.php?t=368013
