1995 trans am coolant sensor
bill blank
02-15-2005, 07:00 PM
where is the coolant sensor located on 95 trans am.
bill blank
02-15-2005, 07:03 PM
FormulaLT1
02-15-2005, 07:08 PM
Which one ?
There are 2.
This one is for the PCM
http://shbox.com/1/temp_sensor1.jpg
and this one is for the Dash temp guage:
http://shbox.com/1/temp_sensor2.jpg
Good luck and welcome to the forum.
John
Which one ?
There are 2.
John
bill blank
02-15-2005, 07:47 PM
the part number for the coolant sensor is 10096163.THE ENGINE LIGHT INDICATES COOLANT IS LOW BUT THE LEVEL IS OK. THE DEALER THOUGHT IT WAS ON THE BACKSIDE OF RADIATOR.COULD THIS BE COOLANT LEVEL MODULE
FormulaLT1
02-15-2005, 07:51 PM
OK your talking about this one.
http://shbox.com/1/low_coolant.jpg
which may be hard to see but its passenger side under radiator cap.
chickenkicker
02-15-2005, 08:12 PM
I've just learned to live with the low coolant light always beeing on, I was gonna replace it when I drained the coolant to replace a hose but I forgot and don't feel like messing with it again. I just ignore it, much like the skip shift light that still comes on even tho it's bypassed.
FormulaLT1
02-15-2005, 08:15 PM
If you disconnect the harness it will make the light go off but you should keep a eye on it then to make sure it doesn't actaully get low. These cars are known to develop coolant leaks.
chickenkicker
02-15-2005, 08:27 PM
Yeah mine already has a small leak comming from the front of the block, gasket behing ps pump I believe. It's been there for more then a year and hasn't gotten any worse than a few drips a day so I'm used to checking it all the time so I might just do that.
