knocking noise
feb
02-15-2005, 10:46 AM
I have an 03 Trailblazer and sometimes when I turn corners, I hear a knock. Sometimes it is on the driver side rear door and sometimes on the other side. What I first thought was that something was on the floor and when I turned, it would slide over and hit against the door. That is not the case though. Anyone else experience this and what is the fix. Other than that, my TB is really great.
Frank
Mr. Northface
02-15-2005, 03:03 PM
Do you have a locking rear end on your TB? (G80 code?)
When taking corners, it can sometimes make a popping noise when the locking rear end is about to give it up & needs to be fixed.
If it is something with the doors, then perhaps the door latches need some re-allignment?
Loose spare tire rattling around?
Jack in the rear side compartment not screweed down all the way?
Something in the glove box or the center councel?
How about in the rear floor compartment? Something moving about in there?
Just some ideas for you.....................
