question about valve cover leak
GTPSPEED
02-10-2005, 01:59 PM
ok i called a local shop and this guy looked my engine up(420a) and said its a 3.5 hour job just to replace the vavle cover gasket so he said i was lookin at $250 in labor alone,,does this sound normal because i thought it was really high,i know its rather easy to do but i dont want to attempt it cuz i know the gasket has to be perfect so let me know if this sounds normal
Killa_DSM
02-10-2005, 05:37 PM
Holly shit!!! That is way over priced!!! Changing the valve cover gasket is really easy. Just take your time when you do it! If I were you i would do it myself. just my .2
GTPSPEED
02-11-2005, 12:34 PM
so there is nothing to it then ok then maybe i will try it,ok cool thanx
scottsee
02-16-2005, 11:36 PM
the only thing to it is getting over the fear of having to pry the valve cover off the cylinderhead if its stuck with a pry bar, flat head screw driver, and a rubber mallet. other then that, its a 20 min job if you've done it a time or two.
helliviknow
02-17-2005, 05:55 AM
Yeah man you can pick up a valve cover gasket for under 20 bucks. I would do it yourself like they said its a easy enough job. Whoever quoted you 250 just for labor is out of there mind! That should be 25 in labor maybe lol
EDIT- Ok for a Felpro Valve Cover Gasket Autozone wants 17.99. Permatex will be another 2-3 bucks.
http://www.autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performSearch&Parameters=Auto+Store%7C%7EREGULAR+PARTS+LOOK+UP%7 C%7EVALVE+COVER+GASKET
GTPSPEED
02-17-2005, 12:05 PM
ok cool,thank you so i can just pop off all the bolts and lift it off and replace the gasket and put it back on thats it,wow ok i will try it and it was a local shop that charged that much i thought it was crazy sounding so i thought about asking you guys cuz most of you seem to know more about these cars than most of the local machanics,thanks
pr0
02-18-2005, 11:27 AM
Wow, and I thought my dealership was a rip off. They wanted $100.00 for labour (gasket included). They said it would be a half hour job, so I just did it myself.
That 100 bucks is Canadian dollars too so its like 70 US.
slowgsowner
02-24-2005, 07:11 AM
easy but remember that to tourque the bolts it's inch pounds not foot pounds read the faq and take your time. The cool thing about it is, while you got the valve cover off you can polish, powdercoat, or paint it. just another reason to dress up your ride. Do it yourself it pays.
AngelOfNight 9
02-27-2005, 08:09 PM
:eek7: WoW... I did my friends car last summer when he was working because it was his B-day. I took the cover off, sanded it down, covered the lettering with tape, painted it blue, changed the plugs, changed the valve cover gasket and the 4 little ring gaskets all under an hour. the gasket itself and the rings would've taken me 20 minutes at most. (Though I was rushing) which I don't recommend you do. lol
xavier3jr
03-06-2005, 03:48 AM
just make sure if u do it urself that u let teh glue dry before u drive the car again give it like 30 min to just sit
