need to fix
ryanb4614
02-10-2005, 01:17 PM
Thought this would be the easiest way to show instead of explaining:
http://www.geocities.com/ryanb4614/myblazer.html
Any ideas of where to get the parts and fix ?Please reply thank you.
BlazerLT
02-10-2005, 01:35 PM
I would check out the local wrecking yard and replace the parts.
Do you have a lot of acid rain in your area?
ryanb4614
02-10-2005, 01:39 PM
BlazerLT
02-10-2005, 01:51 PM
I know, I looked there.
ryanb4614
02-10-2005, 02:00 PM
o my bad sorry haha, do you think all that needs to be done is sanded and a clear coat? Do you know what that part is called that is faded? Also the other picture is it window trim or weatherstrip having trouble finding them.
molehole
02-10-2005, 02:08 PM
It is a Window trim/ Weatherstrip together I believe. You may want to try a Chevy Dealer for that. As for the plastic trim on the sides of the rear window, Have you ever waxed it? Looks like it has had a lot of sun explorsure. Best bet is a junkyard for that or sand it down till its smooth, tape up the area around it and spray it satin Black in a few thin coats. Good Luck
BlazerLT
02-10-2005, 02:13 PM
I would remove them for any painting.
I don't see any real problem with the bottom window trim piece.
ryanb4614
Is that part hard to remove, so i could paint it better? And should i put clear coat over it? Junk Yard here you need to be 19yr old im 16
BlazerLT
02-10-2005, 02:18 PM
You should be able to remove it.
ryanb4614
02-10-2005, 02:21 PM
is it glue or screws holding it in i know there is 2 screws visable from the inside
ryanb4614
02-10-2005, 02:22 PM
Im going to go take off the back tire and take the tire hatch off and sand that down and paint it. So ill be back soon
BlazerLT
02-10-2005, 02:24 PM
More than likely plastic screws.
Just be careful.
Sanding, cleaning and a couple coats of gloss black and clear code and they will be as good as new.
Just be careful.
ryanb4614
02-10-2005, 02:27 PM
im i going to need some kind of glue to put it back on? The tire hatch has like a star shaped screws i dont think i have the tool for it :(
BlazerLT
02-10-2005, 03:14 PM
No, just remove and reinstall with the screws.
ryanb4614
02-10-2005, 03:41 PM
OKay got the tire hatch off. Any idea i went to put in a cd today it ejected and said ERR put 5 different ones in and then put the cleaner in and still says ERR, worked when i bought it :|
BlazerLT
02-10-2005, 04:07 PM
You shouldn't have to remove the tire hatch.
Can't you access the screws from the side that faded trim piece?
swalt
02-10-2005, 04:15 PM
I think he is also painting the spare tire carrier, which is why he removed it.
If you are going to pull off the trim piece, let us know how it went and throw up some pics if you can of how it attaches. I had my rear tire carrier re-painted back in the fall at a local dealer and I asked them why the rear trim was faded/cracking the way it was. They told me it was a combination of the sun, acid rain (the Toronto air we breath) and high speed polishing which wore down the clear coat. They said they had many problems with vehicles they polished with the air buffer and it would eat the clear coat right off them. I also asked them about repainting them and they said they could not get paint to adhere well to them and usually ended up replacing the trim. I would be interested to know how it goes as I was thinking of repainting mine when the weather gets warmer, but I was thinking of doing it on the vehicle and masking everything.
ryanb4614
02-10-2005, 04:32 PM
yes i am painting the spare tirer carrier too. I have to wait till this weather gets warmer its 50 but just have a windchill making it really cold. I took the 2 screws out of the window it got looser but didnt come off could find anything else to unscrew
ryanb4614
02-11-2005, 04:01 PM
Painted it today came out okay, waiting for it to dry then putting on the clear coat. How long should i let the car sit in my garge?
BlazerLT
02-11-2005, 04:11 PM
Let everything dry for at least 24 hrs.
ryanb4614
02-11-2005, 05:51 PM
ok i will do
ryanb4614
02-11-2005, 05:57 PM
Just checked on it hope it comes out, the tire carrier looks good but the plastic doesnt look as good as the other side... maybe it will get smoother looking over night or maybe there is something to buy for that?
ryanb4614
02-11-2005, 05:58 PM
any idea of how to fix the cd player says ERR when i put in a cd,,, blew inside but worked then tried again and didnt work :|
BlazerLT
02-11-2005, 05:59 PM
You should do both sides so it is even.
BlazerLT
Clean it with a cleaning CD.
ryanb4614
02-11-2005, 06:09 PM
the color of it, looks sticky and doesnt look smooth... i did even coats maybe once it dryes.. maybe tomarrow morning it will look different.. I put my clean cd in and it spins then ejects it and says ERR... it suppost to play music while it cleans
ryanb4614
02-11-2005, 06:10 PM
another thing is, i looked in my fuse box today.. there are to wires one is connected in with a fuse, the other is nt, its just laying in there is that normail, or should it b plugged into something .
BlazerLT
02-11-2005, 06:17 PM
I don't know, where is it supposed to be hooked up to?
ryanb4614
02-11-2005, 06:21 PM
ok i guess i will have to read the manual did u ever hear of this problem with the cd player i read that u could press the reset button but i dont think mine has it
swalt
02-11-2005, 06:32 PM
So it sounds as though you got the trim off. Were there any tricks, special clips on the back, etc., that could help everyone else out?
ryanb4614
02-11-2005, 06:53 PM
i just masked everything off i could get it off :| anyone know how i could get my cd player working again?
ryanb4614
02-12-2005, 09:53 AM
Did i use the wrong clear coat? I bought crystal clear, clear coat? Should i have got a high gloss one? To make it more shiny. On my other one the i did not need to paint i could see my reflection in it. This one i cant
rlith
02-12-2005, 10:46 AM
You didn't need to clear coat it at all, all you ever need to do on the black exterior pieces is to use blue cutting gel till it's dull, then use 3M Foam pad finisher on a buffer or rag till its shined...It restores it back to new..We've done this on many of the winburned pieces on various trucks and it's come out perfect every time.
ryanb4614
02-12-2005, 10:51 AM
did u see the pictures it was a rough surface ? i had to be sanded
rlith
02-12-2005, 10:54 AM
Yes, I saw the pics... Very windburned... And even with sanding, (if you have a gouge) 2000 grit wet sanding then using the blue cutter then 3m foam pad finisher would achieve the same thing.
BlazerLT
02-12-2005, 12:46 PM
You do both of them. Not one, both.
You can NEVER match them up perfectly.
