car getting loud at 4000rpm
1Fast_Tsi
02-09-2005, 10:09 PM
the car runs fine but when i get up to 4000rpm its sounds like the car pulls less and exhaust gets really loud and sounds like its right by the driver side floor, dont know why, i didnt see any cracks or breaks in the exhaust or anything like that. can anyone help?
GotGrip666
02-11-2005, 07:53 PM
if you stand by your passenger door/or drivers doordo you feel alot of heat coming from it?
1Fast_Tsi
02-12-2005, 08:14 PM
i would have to check, but would that have to be durring idle or when i rev it up. this problem happened right after i had a new water pump and the t-belt done.
awd_n_it
02-20-2005, 07:10 PM
Your balance shafts are not lined up right. Most likely it's the one in the back. To line it up you have to take out a bolt and put a screwdriver in there to hold it in place. Heres the V-FAQ
http://www.vfaq.com/mods/timingbelt-1G.html
Let me know if this helps :thumbsup:
EclipseRST
02-20-2005, 10:04 PM
Quick question... Are you stupid? Please do not comment on something you do not know the answer too.
A balance shaft has no effect on the tone of the exhaust!
1Fast_Tsi... Your ignition timing sounds like its off, get a timing light and check it, it should be 5* BTDC.
1Fast_Tsi
02-21-2005, 09:35 PM
ill have to get right on that, thx for the help ill let you know what happens.
TreeFrog
02-22-2005, 05:33 PM
my car gets really loud at 4k rpms also, its the turbo hitting full boost... not saying this is your issue
1Fast_Tsi
02-23-2005, 05:20 PM
no i dont think so because it never did this before, i havent had the timeing check yet but should i have the t-belt timeing checked also?
awd_n_it
02-24-2005, 02:45 PM
Just check the timing with a light first cuz it's easy. Remember to unplug you data logger and You will also need to remove the cap and ground the timing adjustment plug before starting the engine. I set mine to 5 degrees BTDC as shown in the shop manuals.
Is the sound coming form your exhaust for sure? or dose it just sound like it?
Dose the motor feel or sound like it viberate's at 4000rpm?
1Fast_Tsi
02-24-2005, 08:44 PM
it sounds like its coming from the exhaust, i also am not 100% on how to check the timing, it vibrerates at 4000 and sounds like something is loose, but it doesnt stop after 4000.
awd_n_it
02-24-2005, 11:51 PM
Redo your timing belt!! Your balance shafts are not lined up right. The (oil pump sprocket) some time's rotates and people don't notice it and they spin it and put it back on it's mark, but what they don't realize is that the oil pump sprocket rotate's faster then the actual shaft, because the shaft is run off gears, this is why they tell you to put a screwdriver in the back of the block to hold the shaft in place.
Here's the information on how to do your "timing belt" they show very good picture's ....
http://vfaq.com/mods/timingbelt-1G.html
*NOTE* if you didn't replace you balance shaft belt i suggest you do so!! It WILL fuck shit up if it brakes!!
After you get your timing belt done you should check your ignition timing with a light, here's the information on it....
http://www.plymouthlaser.com/timin.htm
"YOU HAVE TO UNPLUG YOUR LOGGER AND GROUND THE TIMING ADJUSTMENT PLUG BEFORE YOU START YOUR CAR"
