Blinker noise
blazing
02-09-2005, 10:48 AM
I am getting the sound of the blinker but its not on, when i use my blinkers they work, when i brake the sound goes a way, let of the brake it comes back, is it as simple as a blinker relay ?
blazee
02-09-2005, 11:06 AM
There are a lot of posts and threads on this subject. do a search and you will get tons of info. The brief answer is change the relay, if that doesn't work.... the Multi-Function (turn signal) Switch is bad and needs to be replaced. You can get one from http://www.rockauto.com for about $140
BlazerLT
02-09-2005, 02:15 PM
Might be worth a shot replacing the blinker relay.
Instead of buying one, swap the hazard flash module with the blinker one and test it.
If it goes away, you have found your problem.
blazing
02-09-2005, 03:03 PM
thanks lt, thats the kind of reply i was hopeing for,
did what you said and is a relay :)
BlazerLT
02-09-2005, 03:05 PM
You meant the flasher module?
blazing
02-09-2005, 03:19 PM
and made it positivly the problem,
BlazerLT
02-09-2005, 03:30 PM
Excellent! :D
