Sleeper Vtec on carbs?
BiggieD
02-07-2005, 05:32 PM
I thought i'd run this idea past u guys to see what feed back/info i can get, If i can't find the info I'm lookin for I'll go ahead regardless and document what i find!
I'm wanting to build me an engine using the following parts, D14A1 Block, 1.6 D series crank, rods & pistons, 1.6 sohc Vtec head with 1.4 non vtec rocker cover, D14A1 dual carb inlet manifold mated to Keihin dual carbs from a B20A4 or A3 prelude or from a D16Z6 concerto. Will this work? what variant of the 1.6 sohc internals will give me the correct compresion ratio?
From what I've read on the net I need to remove the Oil jet from the 1.4 block as its alredy mounted in the Vtec head, Use the Head Gasket & T/belt thats matched to the head, 1.6 vtec oil pump, wire in a vtec contoler, can any one solidly confirm this info? Anything else I need to do?
I'm not sure what the Vtec will be like as there won't be any fuel and ignition map change, just cam change! I rekon It will sound mental through the carbs though! once I'm finished, to look at the engine u should see what appears to be a normal 1.4 dual carb but is really a 1.6 Vtec that will still be stamped D14!
Reasons-I have been banned for 1 year(plenty time to research,fund & build an engine) & when I get my licence back need an insurance frendly fast car. My mate owns a 1.3 Swift GTi and we have a little bet, I need to make my 1.4 beat his 1.3 without (visualy) changing capacity(I'm gona cheat) :twisted:
Ewan
Ewan
Hilikus Funkin
02-07-2005, 09:59 PM
i dont think tis possible, carbed engines dont have computers and you need a computer for vtec to kick in...
CivicSpoon
02-07-2005, 10:18 PM
Instead of a carberator(s) why not get individual throttle bodies instead?
BiggieD
02-08-2005, 12:44 PM
hilikus funk-U don't need an ecu to activate the Vtec, theres another way to do it!
civicspoon-throttle bodies would be a costly conversion & would need modified to fit/run & would be an obvious mod visualy. Carbs should fit quite easily and won't look any differant from a stock 1.4 dual carbed engine(I'm goin for sleeper), Carbs should be easily sourced from a breakers yard!
Ewan
Ewan
turtlecrxsi
02-08-2005, 01:01 PM
Can't you just get a beefy cam instead of messing with vtec?
BiggieD
02-08-2005, 03:36 PM
Well I thought bout just installing a cam but decided I wanted to here the Vtec through a pair of carbs. I think if i can get it running it will give good power using stock honda parts, if so i cud then start port/polishing the engine, tuning the carbs etc. Alot of the reason is that I want to do somthing differant & old hondas parts are easily/cheaply sourced from breakers in the Uk!
Ewan
Ewan
Dweezil6969
02-08-2005, 03:49 PM
turtlecrxsi
02-09-2005, 07:34 AM
Check this out, it should help:
http://www.d-series.org/forums/showthread.php?t=1416
That ZC with the dual downdrafts in the wagon looks like the header goes through the radiator or is nonexistent... weird...
BLU CIVIC
02-09-2005, 07:38 AM
ditto...that looked weird
