D15B sohc
Jos4DCivic
02-07-2005, 12:49 AM
will D15B sohc vtec drop right into Si using same motor mounts and everything(other than wiring vtec)? think i might get 1 instead of rebuilding d16a6. what you all think about this motor?
DirtyD777
02-07-2005, 01:11 AM
pretty nice little motor. I was just looking into them afew days ago.
about 130 hp
111 ft. lbs.
Stock mounts will work since it's a D series :)
about 130 hp
111 ft. lbs.
amy@af
02-07-2005, 11:03 AM
and stock tranny, linkage, axles, and pretty much it all
if you want to take it a step further, you can use the a6 ecu + rpm switch (to activate vtec). if you go that route, be sure to remember to use the a6 intake mani (injectors) + dizzy.
rpm activated switch is pretty reasonable, last i checked it was under $70. MSD at Summit Racing....
http://store.summitracing.com and search for part: MSD-8950
