2002 Tahoe Fuel Pump
michaelsjm
02-05-2005, 10:02 PM
I seem to be having same problem as seen by other threads, Tahoe won't start some times at 1/4 tank or less of gas. Add a couple gallons and it starts and runs fine. This has happened twice now. I heard the fix is replace whole fuel pump assembly. I imagine this is difficult to do? Seems to be alot of these cases, have they made a better pump? If one replaces will it just be damaged again in 40k -50k miles? If dealer replaces, do they warranty it so the next time I don't have the high cost again? Thanks for any suggestions.
jim phillips
04-16-2005, 04:00 AM
I have had the same problem as you.Won't crank,put gas in it,crank.The problem is your fuel pump,the fuel gauge sensor is part of the assembly.After my 5th pump on 3 tahoes, I asked the dealer for an extended warranty on the pump,no problem 100,000 miles done deal.It was easier than buying the truck,they know its junk.
BlulytesTB
04-18-2005, 08:54 AM
Had the same problem with my 02 and the wifes 03. Definately an issue. Was fixed after the second pump
