too much compression. what can i do?
96civic_buildup
02-05-2005, 12:54 PM
basically i was wondering if there are any head gasket makers out there than would offer an extra thick gasket to lower my compression a little bit. The kit i was ordering is set up for drag and the compression ratio with a 72cc head is like 10.8 to 1, I'll also be using aluminum heads. So is there any way i could get this down a little, maybe down somewhere around 10.5 or lower? thanks.
Genopsyde
02-05-2005, 01:01 PM
what kind of pistons are you using?
96civic_buildup
02-05-2005, 01:09 PM
JE or SRP 11cc dome, they come with the 355 kit from world products.
Genopsyde
02-05-2005, 01:17 PM
i'm building a 355 also and my compression calculations call for dished pistons.
Morley
02-05-2005, 01:34 PM
If you are using alumnium heads and FI 10.8:1 isn't too high, just make sure you keep the car in tune and if it is FI make sure your prom is dead on.
96civic_buildup
02-05-2005, 02:51 PM
it will carb, and i'm using 195cc AFR heads, i will be running 93 octane only. Are you sure 10.8 is ok, because everybody's told me 10.5 is about the max?
DaMoNe6969
02-05-2005, 03:25 PM
Anyone who makes a metal headgasket will offer them in a variety of thicknesses (ive seen em' up to 2.4mm but im sure they'l go higher) If your using composite headgaskets you could also look into a steel or copper shim to lower compression..
