Shifting out of PARK sometimes a NO GO
HemiGottaLuvIt
02-04-2005, 11:09 PM
About 1-in-5 times after starting my truck, then getting ready to pull out of its parking spot I find that my column shifter will not - shift - into DRIVE. My two workarounds:
1. tap the gas to bring up RPM a bit, back off to idle, then shift
a. works 50% of the time
2. step harder on the brake pedal, then shift
a. works 100% of the time
Have any of you observed this behavior?
Do any of you think this is analogous to a 'neutral-safety-switch' type arrangement? This isn't the end of the world. It's just annoying as hell. Especially because my 98 Ram doesn't exhibit this behavior whatsoever.
superman66
02-11-2005, 08:46 PM
i would check the brake interlock switch, which is usually mounted in the column
HemiGottaLuvIt
02-12-2005, 12:57 AM
Thanks for the tip superman. I'll add it to my short list of things for the dealership to give their eyeball.
