A possible braking problem?
proformancewanabe5
02-03-2005, 11:52 AM
I have noticed for a while that when I put mild to heavy breaking pressure the car pulls to the right, could it be a stuck calaper?
96spyderman
02-04-2005, 05:35 PM
First thing i'd check is tire pressure...
If you have 4 wheel disc with the Ebrake/drum... I had issues with my rear brakes where the piston would push out and not retract that little bit it should.... lots of cleaning and lubing and voila...
You might have an air bubble in one of your lines... maybe try bleeding all 4 cause it never hurts to get new fluid in the lines if that isn't the problem....
just some ideas off the top of my head.... :banghead:
