Where is Audio Amp Relay for Max 95?
LloydMoffett
02-01-2005, 02:01 PM
HELP!
1995 Maxima with Bose system went out (controls still work, display is fine) so I pulled out the stereo and tested it on another. It works fine. Since there is no single amp in this car, it must be the relay. I looked in the service manual and it says that it is somewhere in the front control panel area but for the life of me I cannot find it. I tried following the wires but still no luck.
Can anyone tell me where the amp relay is and how to get it out?
THANK YOU!
THANK YOU!
infinman
02-07-2005, 03:47 PM
The amp relay{called a switching relay}is located behind the left kick panel {by drivers left foot}Remove panel,you will see two blue relays together.One is the switching relay the other is for ignition.As blue relays are the same simply swap the two and see if the amps come on.{Don't forget to swap them back or vehicle won't start}If it doesn't solve your problem ,re-post.Just a note. All Nissan relays are coloured coded.You can swap any colour relay with the same colour.
LloydMoffett
02-12-2005, 12:02 PM
The THREE blue relays in that positon are the blower, ignition, and acessory--any other ideas? Will the amp relay look like this?
