Stock intake silencer
WReX
01-30-2005, 04:07 PM
i heard that if you take off the intake silencer on a stock WRX the turbo spools up faster and is more efficient, anyone had any experience/advice on this?
thanks
freakray
01-30-2005, 04:10 PM
Did you search for the other threads on this?
WReX
01-30-2005, 05:12 PM
i have but i guess my real question is, when i performed this "mod" my wrx seems to lag behind or is being held back until 5000 RPM's, does anyone have any explanation for this?
i couldnt find anyone with the same problem as me
thanks
freakray
01-30-2005, 05:18 PM
Okay, the intake silencer has nothing to do with the turbo spooling, the exhaust gases are what cause the turbo spool so the higher your revs the faster it spools.
If you increase your revs faster the turbo spools faster, all removing the intake silencer does is reduce one obstacle in the path of the incoming air, reducing the pressure acting against the turbo.
WReX
01-30-2005, 05:58 PM
so why does my car feel like its being held back, am i feeling the full affect of the restrictive up-pipe/ pre-cat thing?
thanks for all the info.
freakray
01-30-2005, 06:04 PM
Are you sure you're not just experiencing the turbo lag?
WReX
01-30-2005, 10:03 PM
it may be turbo lag but its lagging until 5000 RPMs it didnt do that when i first got the car, i was also thinking the ECU may be restricting the car until that 5000 RPM point, and this happens in any gear
for all i know, it could all be in my head, haha
donkeyboy
01-31-2005, 11:40 AM
well to prove to yourself thats its not the silencer removal, put it back on real quick and see, but like ray said its not gonna be from the silencer removal...if anything it will help the car
WReX
02-01-2005, 06:40 AM
i might give that a try
thanks
WRXdriver05
02-01-2005, 11:30 PM
thanks
A stock WRX shouldn't lag until 5,000 RPM it should be up and going right around 3,000 and start tailing off around 6,000. The stock turbo, TD04, is a smaller turbo and spools quick. If you really think that it isn't spooling till 5k you need to take her to the dealer and get it checked out......
WReX
02-02-2005, 10:48 PM
Its at the dealer now for power steering failure..for the second time...so ill have them look at it then
i really like warranties...
