Stuck in 4WD!!!!
larryap
01-29-2005, 10:05 PM
We Own a 1997 Chevy Blazer LT. Last night I put it in 4Hi because of snow. This morning it would not come out of 4WD. What should I check first?
BlazerLT
01-29-2005, 11:31 PM
Pull the negative battery cable for 10 minutes to reset the computer.
Should fix it.
Also, you should get oyur transfer case serviced with new fluid.
Should fix it.
bpletcj
01-30-2005, 01:18 PM
I have the same problem sometimes. Even though it should switch back to 2 HI when you put in Nuetral, I sometimes actually have to stop and put it in Park to go back to 2 HI.
BlazerLT
01-30-2005, 02:19 PM
Check your vacuum lines.
corvette68427
02-01-2005, 12:13 PM
I find any 4 wheel drive hard to shift in and out if the driveline is binding. What I do is drive with the wheels straight for a few feet and put in neutral. Some times a miniscual movement of vehicle helps as well.
