Sudden Loss of Power
daniel_becky
01-29-2005, 08:28 PM
I have a 2000 Contour 4cyl DOHC VTC that had a sudden loss of power. It starts and idles perfect. Driving at low speeds is also OK. If I try to go fast or uphill it completly chokes. About 3-4 months the fuel pump went out and had to be replaced. Today I R/R it again thinking it was the problem but still no power. Fuel filter is also fine.
I read somewhere on this forum that the MAFsensor goes out. Do you guys think this could be the problem? How do I test/clean it?
Thanks,
Daniel
daniel_becky
01-30-2005, 10:30 PM
Timing belt slipped over a notch. No I have to have it replaced and figure out why it got loose..
beyondloadedSE
01-30-2005, 10:34 PM
Is the timing belt on the zetec rubber or a chain?
pre98zetec
01-31-2005, 03:10 PM
rubber
jspence35
02-01-2005, 07:25 PM
unplug maf and drive-computer defaults to a sealevel baro reading; does it skip? check engine lamp on?
beyondloadedSE
02-01-2005, 09:41 PM
rubber
well, theres your explanation of why it skipped over a notch.
