T-tops
turd fergeson
01-28-2005, 11:14 AM
Im 16 years old and im looking into a 1998 camaro for my car but theres a problem its well priced but it doesnt have t-tops and i dont know a whole lot about cars i like to think i don but i really dont so i would like to know if its possible to put a t-top in and if it is how pricey would it be i would also like to take out the stock engine and put in a fresh supercharge 350 i would like to know what would be the best trans to put in or just a whole better engine setup if you have any ideas or answers i would be gratefull
Morley
01-28-2005, 12:26 PM
Putting in T tops would run $1500-$2000 and they would leak, aftermarket installs always do.
I take it you don't have the LS1 engine in the car now? Putting in a gen I 350 would be expensive and take a bit of modifications, add to that a supercharger and the price goes up even more. What type of induction were you looking at? Carb or fuel injection? Injection would bring up other considerations, like wiring and ECM/PCM choice and programming. Also, what about emissions testing? Do you have it in your area?
If you are just looking for more performance, I would suggest a used LS1 and T56 trans combo from a junkyard. You'll also need the PCM and complete wiring harness for the engine. This option will also be expensive.
turd fergeson
01-28-2005, 01:38 PM
the enginge in it right now is a 3.8 i would like to put the 350ci / 330hp ''350 H.O. Deluxe'' Engine from jegs and that has a Holley 600 cfm vacuum secondary carburetor and like i sid i dont know that much about cars so im hoping you can tell me what would be best
Savage Messiah
01-28-2005, 02:00 PM
OK well to make a very long story short,
1) use the search feature, this has been discussed countless times; and
2) For the price of that engine, a new trans because you would need one, the new suspension setup, wiring/computer changes, and.. everything... you'd probably be over your head both financially and in terms of doing the work.
Dober89
01-28-2005, 09:02 PM
Aftermarket installs seem to leak alot less than factory. ITs not really worth the hassle but C&C used to install t-tops on hardtop thirdgens. They were built way better than GMs version and sealed up alot better.
DaMoNe6969
01-28-2005, 09:13 PM
It doesnt sound like you really know what your getting into with the 350HO..You would be far better off cash and time wise to sell your 3.8 and buy an LS1 w/t-tops.. The LS1 already has over 300hp and with a little work and some tuning will easily hit 330hp..
But, if you do want to keep your car, I think a Targa/sport roof would be a much better choice..
MMonnier2302
01-29-2005, 03:00 PM
why don tyou drop the 350 in the 85 monte that would be a cool car
Savage Messiah
01-29-2005, 03:34 PM
Ah, there's a 4th gen at my school with targa
