Fuel filter location
dragonsfury711
01-27-2005, 06:06 PM
I have a 1994 chevy lt blazer 4.3lt. vortec v-6 and i have a whining noise in the rear by the fuel pump the fuel pump makes it's normal noise before i start the truck buy then after i start it the whining begins. and i checked the fuses just to make sure and they are good but i can't find the filter and i want to check that before i change the pump cause the truck stalls after it starts and it also hesitates when it accelerates need to find the fuel filter help me please.
JoshBarber
01-27-2005, 06:57 PM
mine does the same. was hoping it was normal
BlazerLT
01-27-2005, 10:24 PM
The whining noise is probably a fuel pump working too hard to push fuel through a plugged filter.
Better get than fixed ASAP or you will wear out your pump.
It is that or your fuel pump is shot.
tyaquint
01-28-2005, 10:53 AM
fuel filter drivers side by frame around torsion bar adjustment
t"
