1996 APV thermostat
ponchmor
01-24-2005, 01:26 PM
My 1996 APV 3.4's thermostat seems to be "sticking" (i.e. won't blow heat upon warm-up and then suddenly heat will blow along with temp. gauge rise and sudden drop). I plan on replacing the thermostat but noticed that the air cleaner assembly needs removed and there is another component that branches from the manifold that passes behind the inlet tube. Does anyone know if there is enough clearence to remove the inlet tube and gain access to the thermostat w/o disturbing this?
rob584
01-27-2005, 11:36 AM
Changed my thermostat in my96 Lumina apv 3.4 You can remove thermostat without removing the exhaust pipe there is room. However it is a tight fit and takes patience. Also make sure the coolant is full because mine has the same problem when coolant is low
ponchmor
01-27-2005, 02:20 PM
Thanks for the heads-up rob584!
jeffcoslacker
01-27-2005, 03:22 PM
True, he might want to check level and bleed the system before putting a 'stat in. That might be all that's wrong. Then the question is, where did the air pocket come from?
