1998 heater will not go to floor
commdb
01-24-2005, 08:01 AM
When I turn the heat to go to the floor the defrost blows, I am having trouble even finding the cables that may be responsible for the damper.
rlith
01-24-2005, 08:29 AM
The damper is vacume controlled.... You may have a leak in one of your octopus tubes.. Pull the controls and start vac tests. Also there is a main vac bulb under the dash that you may want to check.
BlazerLT
01-24-2005, 04:13 PM
When I have my heat set to the floor, I get some out of the defrost also.
If it is set to heat, I think it is normal.
commdb
01-27-2005, 07:52 AM
I only get defrost no floor heat at all. I use to get heat on the floor from the engine almost all the time, and now I get nothing on the floor.
commdb
01-27-2005, 07:58 AM
The damper is vacume controlled.... You may have a leak in one of your octopus tubes.. Pull the controls and start vac tests. Also there is a main vac bulb under the dash that you may want to check.do you have any idea where I might find the schematics for this system or even just a color chart for the hoses and wires under the dash?
rlith
01-27-2005, 08:27 AM
Go to your local GM dealer, usually the service department will print them out for you...
commdb
01-27-2005, 09:54 AM
Thank you so very much, you have been a huge help
rlith
01-27-2005, 10:40 AM
No prob, let us know how it turns out
swalt
01-27-2005, 11:11 AM
Save you the trip.
http://files.automotiveforums.com/gallery/watermark.php?file=/500/116754vacuum_diagram.jpg
(1) Recirculate Air Inlet Port
(2) Heat Port
(3) Heat Mode Port
(4) A/C Mode Port (Vent Mode Port with RPO C42)
(5) Defrost Port
(6) Source Vacuum Port
(7) Vacuum Hose - Blue
(8) Recirculation Actuator
(9) Vacuum Hose - Orange
(10) Vacuum Source
(11) Vacuum Hose - Black
(12) Rotary Vacuum (Mode) Switch
(13) Vacuum Hose - Yellow
(14) Vacuum Hose - Gray
(15) Heater Slave Valve Actuator
(16) Mode Actuator
(17) Vacuum Hose - Brown
(18) Vacuum Hose - Red
(19) Defroster Actuator
(2) Heat Port
(3) Heat Mode Port
(5) Defrost Port
(10) Vacuum Source
(16) Mode Actuator
chembrad
01-27-2005, 12:22 PM
floaterr
02-15-2005, 08:43 AM
If you didn't know already you just have to open the glove box (all the way) and it's right behind it. The one with the metal connector going towards the radio.
