Starting Problems
jdizil45
01-23-2005, 09:48 PM
My car used to start up real easy and then a couple of weeks ago, it takes a while to start up. The engine turns over about six times before it starts up. Help anyone. B 4 the problem gets worse.,
jsgold
01-23-2005, 10:11 PM
Could be a lot of different things. I had a problem with my S-10 Blazer where it started to take a little longer to fire up than used to. In my case the ignition module was failing, so replaced that and coil. You will need to rule other things out first though, such as fuel pressure, plugs, wires, dirty EGR, AIC, and so on. You might want also to list what yours (vehicle year/model) is and engine size, type, etc so you can get specifics. Unsure what you have.
BlazerLT
01-24-2005, 12:05 AM
Ever done a tuneup?
