Engine Removal Gude With Pics (NEW)
Mayday0017
01-23-2005, 07:32 PM
This is is how to Remove the engine and tranny out of an S14 by yourself haveing never done it and doing it in less then 3 hours.
1. Remove engine undercover
2. Drain Radiator (plug is on driver side bottom
3. Drain engine oil
4. Remove air intake assembly (unplug wires as needed)
5. Remove Radiator shroud
6. Remove Fan by removing 4 8mm nuts from back side of fan
7. Remove 2 10mm nuts holding radiator in from top
8. Loosen the 2 radiator coolant clamps (10mm) and remove both
hoses (top first)
9. Remove Tranny coolant lines for those with auto tranny
10. Remove battery from car
11. Behind battery you will find a 12mm or 14mm bolt that goes in by the alternator facing driver’s side loosen bolt
12. If previous step did not cause belt slack for alternator then loosen
more and use force to get slack in belt
13. Remove Radiator
14. under the driver side of the belt assembly you will find a small pulley
and behind it another bolt loosen this bolt out about 1/2 inch then
hit bolt with hammer until there is enough slack in belt to remove.
15. Another bolt is located behind the ac compressor repeat above step
to remove belt.
16. With al belts off take lower bolt out of starter and take tightener
assembly off and remove starter
17. Unbolt power steering and sit the unit inside the stock air box
18. Unbolt ac compressor (NOT THE LINES!) and tie it right below power
steering pump
19. Now starting with ground wire on drivers side of engine next to
exhaust manifold start removing wire harness, wire harness should
be able to be thrown over the side of passenger fender when done.
20. Unplug harness from fuse panel and disconnect any other wires that
hold engine/tranny to car
21. Remove motor mounts using a 14mm deep socket you can take them
off (two nuts)
22. Now go inside car remove trim around gear shifter and take out two
screws towards front of console and 2 inside rear of console and
remove console.
23. Loosen 4 screws holding down copperish plate below shifter.
24. Remove shift link on auto tyanny’s that attaches shifter to tranny
should be a rod about 2ft long (removes w/ cotter pins)
25. Crawl under driver side of car. Remove 2 12mm nuts from center of
tranny cross member and break loose the other 4 16mm bolts that
hold cross member up and remove 1 bolt from each side.
26. Unbolt exhaust from header then unbolt hanger right below driver’s
door (recommend letting WD40 soak on the front bolts while
removing the support bracket
27. Remove center bracket for drive shaft and then remove rear bolts
and remove driveshaft
28. Support tranny and remove other two 16mm bolts
29. Before lowering tranny at all go back up front put engine lift
(cherry picker) in place and support motor weight.
30. Remove the motor mount metal bracket from the engine block on
both sides.
31. Lift engine and tranny at roughly a 35 degree angle
32. Smoke break
http://www.members.aol.com/mayday0021/guide1.jpg
http://www.members.aol.com/mayday0021/guide2.jpg
http://www.members.aol.com/mayday0021/guide3.jpg
http://www.members.aol.com/mayday0021/guide4.jpg
Mayday0017
01-23-2005, 09:24 PM
OH yeah if you like this and want to see more guides like this then say so...
D-Bo
01-24-2005, 12:58 PM
haha i think they wanted pics of some of the steps in removing the engine, not the finished product..
Mayday0017
01-24-2005, 05:23 PM
The hardest thing I at least took a pic of. That is the angle the engine and tranny need to be at to come out. Also the other pics are just so you can glance at them to see what I am talking about when I describe stuff Like where to put power steering pump and ac compressor. Pulling an engine on one of these cars is a walk in the park anyways. You should try pulling the engine on an mr2! Fuck those are a pain in the ass.... done it once and don't wanna do it again unless it is to put one hell of a bad ass engine in.
