1994 jimmy tranny!!!!!!
jakes900
01-22-2005, 09:46 AM
Have any of you guys had a huge problem removing the tranny pan? I took the cross member off then I had to take the filter off in order for the pan to clear the exhaust that cuts in front of the pan. Now I am trying to put it back together. I can't put the pan on first then slide the filter in because I have no room to force the filter in. But if I put the filter in I can't clear the exhaust. I already took the cover off the tor. converter didn't help. I really don't want to drop the exhaust seeing as how I can't reach the bolts at all. Im REALLY close to breaking out the big hammer and doing some slight adjustments. Any ideas or past experiences please help!!!!!
rlith
01-22-2005, 10:02 AM
Usually I put the filter in first, then pry the y-pipe back about an inch, that's usually enough to let me slip it in there, then carefully work the gasket on, line it up, then torque in sequence.
jakes900
01-22-2005, 12:58 PM
thanks that is just about what i ended up doing. i put a small jack under the pan and pushed it up just enough to tap it into place.
