Help! 2001 Camaro electrical? problems...
kkpayne
01-21-2005, 03:13 PM
Bought car new, November 2000. Drivers side power window never has worked correctly. Every part replaced...still problem. Now passenger window does the same only worse. Dashboard lights and headlights "strobe". Alternator replaced 3 months ago. Any guesses as to what is going on with my car?
Xenostalgia
01-21-2005, 03:16 PM
Gnomes...
Jp... Check out your fuse box see if they are alright, see if a 10amp is in a 20 or vice versa etc. Check all the wiring. Sounds kind of like a loose connection with the 'strobe'. Also for the door maybe their is something inside of it blocking and or bad connection at the switch on your door. :)
