indiglo gauges
civicnation425
01-19-2005, 05:37 PM
alright its telling me that i should splice into my headlight switch. which is fine, but would i fully cut it? and connect it straight with the module? or just splice into it. the wire i am talking about is the light wire that runs to my gauges...
Greenblurr93
01-19-2005, 08:05 PM
you could either buy those quick splice things and get it done that way, or strip the insulation off a section of the light wire and the end of the other wire youre splicing to it and solder it on to the power wire, that way u get the best connection possible.
civicnation425
01-19-2005, 08:16 PM
i was planning on on soldering and shrink wrapping, but do i connect the wire to the exsisting wire running to my cluster? the one that lights that up?
Greenblurr93
01-19-2005, 08:52 PM
not sure.. it makes sense, but i havent installed indeglos yet.... check your instructions.
civicnation425
01-19-2005, 08:59 PM
oh way ahead of you, i always check those first before i consult with you guys... but its just generic and and doesnt tell me which wire i need to install if on, thanks for the help tho
