sudden loss of power
ms_smartypants
01-19-2005, 04:45 PM
I was driving along hearing a buzzing sound that did not hurt the power of my turbo at first but then it sounded like something snapped and I lost most of the power and was barely able to drive the car home. Thought it was the timing belt. But no It was perfectly aligned and only the little balance belt was a little loose. Did a compression test and all cylinders have the same compression over 150 lbs. Checked the turbo and it spun freely and appeared just fine. Once I turned the car off I was never able to get it started again. Should I pull the pan and look for lower end problems. What could have made the buzzing noise and what sounded like it snapped. ????
EclipseRST
01-20-2005, 05:21 AM
Well you got compression, now its time to check for fuel and spark... Those 3 are the key ingrediant to a running motor! Check for fuel and spark and let us know what you find.
ms_smartypants
01-20-2005, 03:29 PM
I smell gass after I start it and I get spark on all cylinders when I test each plug wire separately
ms_smartypants
01-20-2005, 03:33 PM
I've got good spark on all cylinders and I smell gas after trying to start it.
This car has over 300,000 miles on it. What else goes bad?
I took the alternator belt and power stearing belt off and timeing cover off then i put the motor mount back on and stated the car. It started again but although the timing belt is not rubbing it is still making a buzzing noise that gets more like a whirling noise as I give it gass. All the accesories are disconnected. what is that buzzing whirling noise???
EclipseRST
01-21-2005, 05:14 AM
Good question... Dont run your car without your water pump or you are going to toast your motor!
I'm starting to think you need a rebuild if your car has 300,000 miles! :eek7: That is just insane if it is the stock motor. Some sort of world record. You should do a compression test (go to autozone and sign up for the loan-a-tool program if you dont have a compression tester) and check your compression then post it up here what each cylinder is.
ms_smartypants
01-21-2005, 04:23 PM
Hey- DUDE ... 'sup? You're asking what I already stated in my post. Stay out of the troubleshooting business if you have nothing to offer. By the way, don't ever believe the miles on an engine dictate anything. Take care of it, it'll last and last - gotta mustang w/500K!
talonlover
01-21-2005, 09:54 PM
Have you checked all the intercooler hoses to see if anything has blown off or come loose?
1stGenRocks
01-21-2005, 09:58 PM
you're full of shit if you have a mustang with 500k on the stock motor. the world record for a motor is like 300 something on some old volvo in england. unless you're talking about KM instead of Miles
EclipseRST
01-22-2005, 03:49 AM
Haha... Ok moron, you didnt eve tell us what car you are asking about, put your car in you sig before you start asking questions or this thread will be closed!
I answer so many of these retarded questions each day I dont remember exactly what I asked already so if you are going to be a smart ass about me trying to offer you ideas get the fuck out of my forum!
