Cylinder 1 misfiring?
wongb18c
01-18-2005, 09:40 PM
Recently while driving CEL suddenly poped up, later on I got my CEL checked, the code says something about cylinder 1 misfiring. I don't know what can cause this. Does anyone know a solution for this? [heh I know this is a really bad thing] What can I do?
Only thing I can think of is that recently I drove the car for about a week with no airfilter. But that shouldn't cause ignition problems ? Some input needed.
1stGenRocks
01-18-2005, 10:02 PM
clean your throttle body and intake. a misfire code can be caused by a lot of things. since you drove without a air filter my guess would be that you just need to clean your intake and upper engine.
coolguycooz
01-18-2005, 11:02 PM
check your plugs and wires .
Urban_Squrill
01-18-2005, 11:42 PM
Change your oil. Going with out an airfilter can make your oil dirty.
Legionofone
01-19-2005, 12:37 AM
going without a filter could... FUCK UR CAR UP!!! my cirrus sucks air right up from the ground level under the grill and is rammed up inside :) if i dident have a filter I WOULD BE SCREWED HARDCORE! so my recomendation would be to realy get that engine looked at
wongb18c
01-19-2005, 01:24 AM
Thanks I'll check plugs/wires.... and will change the oil.. if that still doesn't solve the problem I'll go from there.
Edit: Also do you guys think it could the be the injectors or distributor?
1stGenRocks
01-19-2005, 06:10 PM
not very likely that its the injectors. and i'm just about positive that its not the distributor because 2g's dont have them lol
