instrument cluster
dsmodder
01-18-2005, 05:22 PM
hey anybody know if the 88-91 crx si intrument clusters are compatable with a 88 crx hf?? my speedometer is broke and i need to replace the cluster but cant find any hfs. help
Josh95cx
01-18-2005, 05:28 PM
any 88-89 will work any model crx, also 90-91 have different wiring, so be careful when buying one not to get the wrong one. A 90-91 one will work but will require rewiring and a different cluster hood.
Leesmack
01-18-2005, 05:48 PM
what instument cluster from integra fits 90 honda civic hb?? is it hard to install
Josh95cx
01-19-2005, 02:54 AM
The 90-93 integra cluster works with rewiring the dash harness,but will not fit under a stock cluster hood, so you will have to modify yours or use a 90-93 teg dash. You can however swap a 99-00 si cluster, crv cluster , or integra cluster from a 94-01. Here is the link to the Si/crv cluster swap. These also require a electric VSS, but the 90-93 doe's not.
http://faq.ef-honda.com/index.php?sid=30075&aktion=artikel&rubrik=003&id=6&lang=en
dsmodder
01-19-2005, 09:25 AM
thanks alot fellas
