Display case
Coronet
01-18-2005, 11:17 AM
I've thought a long time to build a display case. A week ago I decided to see if I could plan a simple desing and I was pleased with my desing. :)
Here's a 3D model of the display case.
http://koti.mbnet.fi/scherman/vitriini/vitriini.jpg
After I had drawn the model, I did do some calculations and decided that the display case is going to be 1300mm(=51") wide, 800mm (=31") tall and 120mm(~5") deep. The wood is 15mm(~3/5") thick.
I'll build the shelves(?) out of 8mm thick clear acrylic glass. For the backplate I'll use acrylic mirror if I can find some.. And to front the I'll use clear acrylic..
Yesterday I bought some wood and decided to begin the building. So far I've cut the slots for the shelves.
First I sawed two 5mm deep grooves with a metal saw blade.
http://koti.mbnet.fi/scherman/vitriini/tera.jpg
Then I milled with the Dremel the center of two grooves.
http://koti.mbnet.fi/scherman/vitriini/jyrsitty.jpg
And after a couple of hours work, the result is this:
http://koti.mbnet.fi/scherman/vitriini/valmis.jpg
I still have to sand every part before I can start assembling the case.
Feel free to comment. :)
Vric
01-18-2005, 11:27 AM
nice
btw, Alex did the same case and did an "How-to"
http://italianhorses.net/Tutorials/Display/dcase.htm
Coronet
01-18-2005, 12:03 PM
nice
Yes, I carefully examined his display case and took a lot of influences to my display case. Thanks Alex! :)
Coronet
01-21-2005, 09:46 AM
I've assembled and covered the display case with lacquer.
In my opinion, the case looks pretty good, although I had to use brush for the lacquer.
Also, I looked some prices of clear plastic and I was stunned by the prices. A piece of one square meter plastic, 8mm thick, costs around 100€..
I'll have to ask if I could get some kind of discount.. :)
http://koti.mbnet.fi/scherman/vitriini/DSCF0001.jpg
ales
01-21-2005, 11:07 AM
I was also quite astounded at the price of plexiglass when I was getting it for my spraybooth. I think you could try using regular glass, it should be somewhat cheaper, and look better, you'll just need to be careful with it and think everything through.
Vric
01-21-2005, 11:19 AM
tick plexi is expensive. if you get it smaller, it's not that expensive. I use it for different mod (no modelling) I use 3mm or 4mm and it's cheaper than glass.
8mm is VERY tick for a "window"
My Model dispay is mode with Glass. it cost about 8$ by row + 30$ for the window. I can put 8 model by row, 8 row (64 model) Will need to built a new one soon :lol:
Coronet
01-21-2005, 12:18 PM
I'll use the 8mm plexi for the shelves. I'll ask if I could get some "left over" parts, I think it would be cheaper..
I don't know about the glass. I am not very keen to use it because altough I could get the glasses cut in the shop, the glasses still need a of bit work. (the front edge must curved)
To the front I'll put something like 2-3 mm thick plexi..
Vric
01-21-2005, 02:12 PM
Well for me, the store cut it with rounded edge for about 1$ by cut..
ales
01-21-2005, 05:21 PM
Yup, the shop that cuts it can also finsh the edges. Wouldn't hurt if you ask around and see the situation beofre making a decision.
Coronet
01-28-2005, 08:48 AM
I got the display case finished.. Well, I didn't use plexi glass. :)
I talked with a friend of mine, who owns a local glass cutting shop, and he said that 8mm thick plexi bends over 3cm in a length of one meter.
I decided for the glass also because it was a lot more cheaper than plexi.
I got the mirror and the glasses for 58 euros..(a 50% discount.. :smokin: )
I am very pleased with the end result.
Here´s some pics..
http://koti.mbnet.fi/scherman/vitriini/lasit.jpg
http://koti.mbnet.fi/scherman/vitriini/valmis2.jpg
Now, I just need a lot more cars so that the display case won't look so empty... :)
joelwideqvist
01-28-2005, 09:05 AM
Nice work, but in my opinion the mirror ruined it all...
/Joel
