93 shadow starting problems
Bikefreak
01-17-2005, 11:40 AM
:confused:I am havig problems starting this shadow. It has a brand new battery and was working fine however it seems over night it has developed a battery problem and won't start.If the car is left over night it will drain the battery. If i charge it for about 10min it will start and run fine. Anyone have any ideas? where should i start? This car has the 3.0 v-6.
Thanks
theFREAKnasty82
01-17-2005, 10:05 PM
you could have a module not powering down when you turn your key off. Best way to check that is get an ammeter, disconnect the negative cable and hook the positive lead of the ammeter to the battery cable and the positive lead to the battery post itself. If the reading is more than 100 milliamps, you have a serious power drain. If you have the 3.0 V6, it's either the SBEC, TCM (if it's the 4-speed unit).
