93 Supercharger Tubes
mr.goodwench
01-16-2005, 09:44 AM
Does anyone know how to put those large diameter, as in 3 to 4 inch or so, supercharger tubes back together on a 93 sc tbird? I needed to pull them off to get to some other parts needing replacement and the previous owner had used silicone. Ford told me three o-rings are needed, but there are obviously four connections. Which connection doesn't get an o-ring or was ford's parts person wrong?
DMS825
01-16-2005, 11:45 AM
It's perfectly okay to just use a thin bead of gasket sealer. I've done both of my cars that way and they work just fine. I use the orange high temp kind.
8ate8
01-16-2005, 01:51 PM
You best bet when resealing the tubes is to use tbird88s IC gaskets. Go to the sccoa forums and contact tbird88 and tell him you want a set of IC gaskets. I believe they are $40 and are made of teflon.
