SVT help
JimR
01-15-2005, 04:31 PM
ok i cant get the thing to start. its cold out so its in the gradge "gradge is warm". it cranks and cranks. but wont fire. spark ok, pump ok, oil ok, dont know why it wont start.
thx for the help
beyondloadedSE
01-15-2005, 05:09 PM
have someone give you a push and pop the clutch. Its probably flooded. Once you get it started, turn it off and see if it will come back on. Its happened to me before. I had my brother give me a push down the driveway, popped the clutch and it started, but a ton of black smoke came out from all the excess fuel. It was fine after that.
landyacht
01-18-2005, 12:50 PM
If that doesn't work i'd have a look at your wires to the spark plugs. I have a friend that had issues with his popping off about every couple months.. might be what happened to you.
vintweed
04-04-2005, 12:45 AM
Crank 'er over while holding it 'to the kitchen'...
Works for flooded carb'd car's, and fuel injected ones too....
