how many quarts/bottles of tranny fluid do i need?
fierce
03-10-2002, 11:49 PM
to completely change the fluid.
WickedSSH22a4
03-11-2002, 02:01 AM
Auto or stick? If auto..I believe between 3 - 4 quarts will do for a drain and refill. You only remove approx 33% of the ACTUAL fluid each time you do a drain and refill though...So to get it COMPLETELY changed, gotta do 3x or take it to a shop that has a flusher machine...Again, this is for Auto only....
fierce
03-11-2002, 02:32 AM
manual tranny :cool:
fritz_269
03-11-2002, 05:43 PM
About 1.9 liters for the Base, 2.1 liters for the SH.
Just buy 3 liters, that way you have enough to flush a little.
If you drain out on a level surface, you'll empty about 95% of the fluid. Also make sure to use a new washer on both the filler and drain plugs.
:cool:
:cool:
