Clutch Click
fussman238
01-14-2005, 05:16 PM
Ok first off I dont have much knowledge about clutches but anyway Im kind of scared right now. After driving pretty agressively for about 5 mins I cooled down and heared , and felt my clutch pedal click. I pressed it down a few more times and it clicked every time I pushed my clutch to the floor. As of now it dosent do it every time i shift but almost. My car has 90k miles with the stock clutch
1stGenRocks
01-14-2005, 05:21 PM
YEAR MAKE AND MODEL OF CAR IN SIG! also a better description of how you were driving when before it started. were you shifting without the clutch? dumping the clutch? shifting at redline? or were you just going fast?
fussman238
01-14-2005, 11:54 PM
97 gsx 90k miles, I grinded 2-3rd and redlined from 3rd to 4th goin real fast i think my sars hurt
BTW How do i get my sig to show up?
kjewer1
01-15-2005, 07:39 AM
Should all be under the "User CP" link above (User Control Panel). Is the click coming from inside the car or does it sound muffled, like it could be in the engine bay.
fussman238
01-15-2005, 02:36 PM
it sounds like right near the pedal
david-b
01-15-2005, 03:35 PM
Mine does the same. My mechanic says one of the springs in the clutch broke. I think he just wants my car!! I've been driving with that popping for awhile now. It sounds like its at the pedal, but if you open the hood and have someone hit the clutch, it'll sound louder in the engine comparentment. Mines been doing this for a long time now (6months), and Ive had no problems at all. You get used to it. As long as you can shift, it doesnt pop out of gear, and doesnt grind, you should be ok.
guitarXgeek
01-15-2005, 03:55 PM
Is it like a double click or just one solid click? Say, is it one click when you push the pedal in, and then another click as you let it out? If so, I believe that's just the cruise control switch that lets it know when the clutch is depressed while cruise is activated. I've been under the dashboard when the pedal was depressed and the clicking sound comes from that exact switch. Of course, your clicking could be something completely different. I'm just throwing stuff out there ;)
fussman238
01-15-2005, 04:06 PM
wongb18c
01-15-2005, 11:12 PM
Don't want to steal the thread or change the topic but I didn't want to start a new one and make everyone mad.
My car is a 99 RS with over 110k on it. I bought the car used last year with 90,xxx something. I never asked the previous owner when the clutch was changed. I'm not an expert with clutch/tranny or cars for that matter but I know that this clutch on the car is at the end of it's life but I'm not 100% sure it's the clutch.
***Recently driving around, I noticed when engaging the clutch.. and adding gas... the car studders.. or how do you say... bogs and vibrates a little. After the clutch is fully engaged.. sometimes when I add gas the car bogs again. I don't get good acceleration.. it also takes the car quite awhile to get going from a stop. So does this sound like that the cluch definitely needs to be changed? I want to make sure that this is the problem before I spend any money to change it. Also if it is the clutch, what else should I tell the mechanic to change while he's at it? Also how much am I looking at to pay, for a local mechanic to do this job[so I don't get ripped off]? I wish I could buy a clutch kit and do it my self but I don't have the experience or the tools, or someone else to help me for that matter. TIA for any advice/suggestion.
One more thing, the clutch pedal feels a lot 'looser' than before.
metalhedskater
01-16-2005, 01:42 AM
My clutch makes the same clicking sound when i depress the clutch. I thought it was normal as well, and i havent had any problems with it.
97GSTspyder
01-16-2005, 01:52 PM
mine did that for a long time...my mechanic said it was the master cylinder rod that comes through the firewall and to the pedal. he said it's nothing to worry about. he said an adjustment might help, but now my tranny/clutch is out of my car which doesn't help anything! lol
spyderturbo007
01-18-2005, 09:34 AM
It is probably one of the springs on the clutch pedal. Nothing to worry about, it's a common problem. There is a fix for it but I can't remember where I found it. The problem is under the dash, not with the clutch itself.
fussman238
01-19-2005, 08:33 PM
:UPDATE::UPDATE::UPDATE::UPDATE::UPDATE::UPDATE:
Last monday my transmisison blew! argh i dont know if the clicking was related but now i am pissed !!! argh
97GSTspyder
01-20-2005, 01:13 PM
that sucks...the tranny for my car at the dealer here is $1900! i found one at a junk yard though with 37,000miles on it for $950
fussman238
01-23-2005, 05:53 PM
Im an idiot, i got it checked out after i calmed down and it turns out the slave cylinder blew (idont really know what that means) haha but anyway its only 100 to fix at my garage so im really relieved
97GSTspyder
01-23-2005, 07:19 PM
100 bucks? damn that's a lot to change a slave...on e-bay they're like $40 - 50 and takes 15min to replace...the slave cylinder basically pushes the throw-out fork which in return pushes the throw-out bearing against the pressure plate to disengage the clutch. when you said your tranny blew, what was it doing? you probably weren't able to select gears smoothly, or at all right? probably because since the slave blew, it wasn't able to disengage the clutch completely...you might wanna look into getting a new master cylinder at the same time...it'll probably save you another headache later on down the road.
