Multifunction Switch
AgentBman
01-13-2005, 04:17 PM
I thought I had a problem with the switch, but I took the cover off and have found that three different wires have broken. A pink, a green and a beige wire. One goes to the cruise, the others (i assume go to the low beam because they are not working.) Does anybody have any wiring information on these wires? I have bought new connectors to use, but am not sure which wires goes into which slot. Thanks for any assistance!
debrey
02-09-2005, 11:41 AM
Hi Bman. I have the same problem with my 95. Is it hard to get at the wires? Do you have to remove the steering wheel and other difficult parts? An airbag wire is also broken in there because the airbag light would go on and off if the steering wheel was lowered or raised. The cruise and high beams have stopped working also, so I'm pretty sure the wires are broken.
AgentBman
02-09-2005, 12:55 PM
I had to bite the bullet and let the shop do it. The part included the needed wires and cost me 250.00. Shop charged me additional 70 to put it on, but now it works fine.
