where are door sencors located?
JamesD
01-13-2005, 09:34 AM
And what do they look like? I've tried to find them to clean them but can't locate.
Problem: Door Ajar light stays on; Interior lights stay on (unless I shut them off at control panel); key in ignition alarm sounds even if door is closed; radio shuts off before door is opened.
seems like all things associated with the door being opened or closed are malfunctioning.
I have an appt. for Saturday to get looked at. Problem, while this is happening 90% of the time, if it isn't happening Sat. they said they wouldn't be able to locate the problem. So, I figure I will try clean the sencors to see if that solves the problem.
thanks
XLT03
01-13-2005, 09:17 PM
Sensors are located inside of the door above the latch. Your problem is common. Use WD40 and spray into latch, use lots of it, close and open door 6 times. Spray some more, Repeat on other doors. Problem should go away. If not repeat again. Same solutions for Ranger trucks. Cancel your service appt.
JamesD
01-14-2005, 09:56 AM
thanks for the info i'll give that a try. it had stopped for a day. Then this morning after my wife went to the grocery it started again.
XLT03
01-15-2005, 12:54 AM
Don't wait too long, you may drain your battery or you won't get your car started. You know what to do.
