lubing the slip joint on 2 piece drive shaft????
ptc1625
01-12-2005, 10:15 AM
hi ive been reading alot the past few days about people lubing thier drive shaft??? what exactly are the steps to do this??? do i just rub grease all over where he two pieces meet? and help would be greatly appreaciated
amigo-2k
01-12-2005, 11:03 AM
you maybe lucky and already have a zerk to squeeze some grease into into it.
The clunking and thumping is common on the 98-03; 2004 these switched to a 1 peice unit (wonder why?).
ptc1625
01-12-2005, 11:30 AM
i have a 92, im not sure if it has a zerk or not, if it doesnt, what are the steps to grease it
amigo-2k
01-12-2005, 12:52 PM
http://www.eurekaboy.com/f250/slipjoint.htm
you can you the above as a reference. Also, I would suggest purchasing a manual (costs about 20 bucks; google for it).
ptc1625
01-12-2005, 01:01 PM
rodeo02
01-12-2005, 01:55 PM
... what are the steps to grease it
Same as the instructions link Ryan provided. Remove the flange bolts at the differential input, pull/cut the clamps off the boot. Slide the driveshaft apart, clean, regrease, reinstall. Make sure you line everything up the way it was for balancing purposes.
G/luck
Joel
G/luck
Joel
